A VLAN-based traffic group links all ports in a VLAN to an egress QoS profile for traffic forwarding. All intra-VLAN switched traffic and all routed traffic sourced from the named VLAN uses the specified QoS profile.
To configure a VLAN-based traffic group, use the following command:
configure vlan vlan_name {qosprofile} qosprofile
If you are using ACL-based traffic groups, use the qosprofile or traffic-queue action modifier to select a forwarding queue. Traffic that meets any ACL match conditions is not evaluated by other traffic groups.
VLAN-based traffic groups apply to all packets.
